SBC water pump,bracket set up, distributor, coil, carb
Moderators: lightemup, mouth
Frylok
Post by Frylok »
v6/v8 bracket set up with new water pump, new a/c bypass pulley, new alternator for 92 s-10 v6 and crank pulley - $200
New stock Distributor and MSD coil from 88 monte carlo SS, has 10 minutes on it switched over to non feed back carb set up - $125
Stock carb from 88 monte carlo SS could use a rebuild but ran pretty good - $75
Rocker studs and push rod guide plates, 3/8-24 comes with new lock nuts - $45
ARP 8750 7/16 connecting rod bolts new never used set of 16 - $75
any offers welcome
