79 chevy bbc 2wd sb drag truck roller for sale
Posted: Thu Nov 27, 2014 12:46 pm
For sale is a 79 2wd chevy short bed Ive had for 20 years Raced it in quick 8 Set up for bbc 632 truck has the following: Ford 9 inch rear 35 spline with gun drilled axles
spool 411 pro gears aerospace disc brakes all around ladder bar sus...pension with adj coil overs all around wheelie bar pro launcher chute mild steel cage all tigged and will cert to 850 aluminum bed floor and cover painted to match truck dual nitrous bracket alternator on bracket mounted to third member rear power shut off in rear pan and charging lugs too.
Has 2 painless wiring panels in cab with a set of race buckets power window and door locks all autometer guages front end is coil over tubualar a-arms with mid plate and mounts for front motor plates has a magna flow 500 pump and filter with 2 gal fuel cell in front fiberglass front bumper and cowl hood the rest of the truck is all steel with stock frame has pro stick shifter dedenbear glide roller tail shaft fresh with all new parts 10" ati nos converter 2.5 custom headers with egr bungs for big chiefs for slip on mufflers. Has weld alumastars all around with 15x3.5 front and 15x15x32 mt slicks Truck weighed 3400lb with 632 aluminum bbc been 812 et and 170 mph 1.26 60 ft all you need is motor and msd box and you can go racing 12,500.00 Firm or Trade for mud truck have cash if its the right truck ????? I have additional photos if interested Thanks 609-548-8829 See More
