---1981 Malibu Wagon---(SOLD)---
Engine – 355 SBC 4 bolt main
Scat crank
Eagle rods
Comp cams extreme energy cam and lifters Hydraulic Flat Tappet, Advertised Duration 284/296, Lift .507/.510
Crane 1.5 full roller rockers
Howard’s cams one piece push rods
Edelbrock guide plates
Fel pro head gaskets
Edelbrock performer RPM aluminum heads
Melling oil pump
MSD 6AL box
MSD pro billet distributor
MSD wires
Double roller billet timing chain
Billet aluminum timing cover
Holley 130 gph mechanical fuel pump
Lightweight fuel rod
Summit mini starter
Summit flexplate
Holley 750 chokeless race series carb
1’’ carb spacer
Professional products single plane intake
K&N filter and extreme lid
Fabricated aluminum valve covers
Schoenfeld 1 5/8 primary headers
Wieand twisted snout high volume aluminum water pump
Summit aluminum radiator
Flex-a-lite 2600 cfm electric fan ( automatic with manual override switch )
Be cool temp fan controls
Milodon high flow thermostat
New engine mounts
Comp cams vaccum canister
Trans- TH350
Professionally built TH350 filled with B&M trick shift fluid
Redneck 9 inch converter 3500 stall
B&M two quart extra capacity aluminum trans pan
B&M shift kit
Flex- a-lite 6 pass aluminum trans cooler with -6 inlet and outlet
Braided stainless hose from trans to trans cooler with -6 fittings on both ends
BMR driveshaft loop
G-force crossmember
New trans mount
Hurst quarter stick pistol grip shifter (ratchet shifter)
Stock drive shaft ( have a 4” aluminum one to replace it, needs to be cut and new u joints installed by a professional driveshaft fabricator )
Rear- 10 bolt
Moser 26 spline axles
Auburn posi unit
Richmond 373 gears
Polyurethane bushing for upper control arms Aluminum rear drums
New axle bearings
Jegs aluminum girdle rear diff cover
Welded axle tubes
Suspension
Competition engineering drag shocks 3way adjustable in front and rear
Moog tie rod ends
Iceman rear adjustable upper control arms
Iceman rear lower control
Lakewood slapper bars
Front wheel bearings new
Brakes-
New front calipers
New front pads
New front rotors
New wheel cylinders in rear
New rear shoes
Exhaust-
2 ½” true duals
Two super 40 flow master mufflers
QTP electric exhaust cut outs (switch on dashboard)
Wheels & Tires-
Torq thrust wheels 15x 8 rear – 15x 3 ½ front
Mickey Thompson Drag radials 275-60-15 in rear
Kumho skinnys up front
Body-
Harwood fiberglass 4” cowl induction show hood
GNX air vents in front fenders
Luggage rack shaved
Nomad style chrome bars on tailgate
Body is straight few little spots of rust one on driver a pillar, couple small paint bubbles developing at roof drip rail on driver side, passenger rear door small rust spot. Needs door weather strips replaced, they seal but don’t look so good. The interior is decent.
Have fiberglass replacement bumpers for front and rear.
The paint is decent but some scratches from the kids…
No rust on the undercarriage the car, solid floors and frames rails.
Mechanically done right, just needs very little work on the body. The car was only ran at the track twice with three passes each time, it ran a 12.74 in the ¼ mile at Atco. It has the power to go faster.
It’s ready for the race track or just cruising… Great car, sounds good and turns a lot of heads!
Many spare parts for car as well… Asking price $6900 OBO Make me a offer! Clear PA title in hand...
SOLD
- 81wagon
- 81wagon
Re: 1981 Malibu Wagon (street / strip)
pm me for more pics...
81 Malibu Wagon w/ a 355, 350 trans w/ 3500 stall converter and 373 gears out back
- 81wagon
Re: 1981 Malibu Wagon (Price Lowered)
bump...
