The 2009 Shakedown At E Town Class Rules
PDF Version Available at http://content.godragracing.org/2009shakedownatetownrules.pdf
PO Box 143, Lawrence, NY 11559
516-322-8142
516-284-6926 Fax
Raceway Park and New York Motorsports Host the
Al Anabi Racing 7th Annual Shakedown at E’town
2009 AL ANABI RACING SHAKEDOWN AT E’TOWN RULES
LEND AMERICA PRO MOD BLOWN
Rules:
- • For cars with blowers, turbos or centrifugal superchargers
• No screw blowers, NHRA/IHRA legal blowers only
• Single power adder only
• No minimum weight
• Must be Pro Mod type door car with working doors.
• Diaper/oil retention device required
• No altereds or dragsters
• Courtesy staging in effect
• Auto start on, set at 7 seconds.
• All NHRA safety rules, license, and chassis requirements in effect
SPEEDTECH PRO MOD NITROUS PRESENTED BY WESTERN BEEF
Rules:
- • For cars with nitrous assistance
• Naturally aspirated vehicles permitted
• No blowers, turbos, or centrifugal superchargers
• No cubic inch limit
• No minimum weight
• All NHRA safety rules, license and chassis requirements in effect
BARWA OUTLAW 1/8 MILE CHALLENGE
Rules:
- • Must be Pro Mod type door car with working doors
• Any power adder
• Multiple power adders permitted
• No minimum weight
MICKEY THOMPSON TIRES OUTLAW 10.5 PRESENTED BY PRECISION TURBO
Rules:
- • 3,000 lb. base weight
• Must run 10.5 tires only, no big tires
• No Pro Modified cars or full round tube chassis cars
• Single (one) power adder only
• Auto start on, set at 7 seconds for timeout
Deductions:
• Naturally Aspirated – deduct 400 lbs.
• Small Block NOS – deduct 600 lbs.
• Big Block NOS – deduct 200 lbs.
• Single Turbo - Small Block – deduct 200 lbs.
• Single Turbo – Big Block – deduct 100 lbs.
• Twin Turbo - Small Block – deduct 100 lbs.
• Twin Turbo - Big Block - no deductions
• Small Block Blown – deduct 200 lbs.
• 4 & 6 Cylinder – deduct 700 lbs.
K&K PRECISION HEAVY STREET
Rules:
- • 3,200 lb. base weight
• Square tube entries permitted
• Factory produced cars with VIN numbers
• Any tire size allowed
• All NHRA safety rules, license, chassis requirements in effect
Deductions:
• Naturally Aspirated – Deduct 600 lbs.
• Nitrous 650 & smaller – Deduct 400 lbs.
• Twin turbo big block - Add 300 lbs.
• Clutch assisted cars – Add 100 lbs.
• Round tube entries – Add 100 lbs.
PRO TORQUE DRAG RADIAL
Rules
- • 3,175 lb. base weight
• DOT Radial Tire, max 12” measured tread widths
• Factory transmission & converter, OEM stick acceptable
• Second (2) power adder permitted on Imports
• Stock type suspension, direct bolts replacements acceptable
• Wheelie Bars NOT permitted
Deductions:
• Small Block Nitrous, 4 Cylinder & 6 Cylinder – deduct 600 lbs.
• Big Block Nitrous – deduct 300 lbs.
• Naturally Aspirated – deduct 600 lbs.
WESTERN BEEF 8.50 INDEX PRESENTED BY FINELINES AUTOMOTIVE
Rules:
- • To qualify for the 8.50 Index race, you must be 9.00 seconds or quicker. In order to expand the eliminator in the 1st round, the qualifying field must be 9.00 or quicker for all cars. In qualifying, if anyone runs quicker than 8.50, you are placed at the bottom of the ladder. If you run quicker than 8.50 in eliminations, in a double breakout, the driver closest to 8.50 wins. If you run faster than your car chassis is certified to run by the NHRA, you will receive a warning. You will get three warnings. After the third warning, penalties will be enforced including round loss and loss of points.
• Sportsman ladder
• .4 Pro Tree/Heads Up/No Breakout/Quickest ET gets lane choice
• No Deep Staging
• Maximum tire 10.5” (example: W33.0/10.5-15W)
(All cars running 11.00 and quicker must have metal, screw-in valve stems.)
• Any race fuel permitted including alcohol
• Minimum vehicle weight: 2800 lbs. for Small Block/3000 lbs. for Big Block
• Auto Start set at 7 seconds. Courtesy staging in effect.
Body/Interior:
• Full-bodied factory rear wheel drive street type cars
• A ribbon-type window net SFI Spec 27.1 is mandatory on full bodied cars that are required to have a roll cage
• Must be street appearing/no gutted interiors/carpeted interior even if rear seat is removed (The interior should look clean and professionally done)
• No car will be permitted to go faster than the Chassis is certified for by the NHRA
• Must have door panels
• Racecar lettering on windows only (Sponsor Logos permitted)
• Height on hood scoop to be a maximum 9 inches
• No one-piece fiberglass front ends
• Back half or stock suspension permitted
• Windows, Lexan permitted (Roll down windows optional)
• Must have stock style front suspension
• No full round or square tube chassis cars
• On board fire extinguisher is permitted and recommended
Electronics:
• Bracket Racing Aids: No throttle stops, No Electric shifters or Optical sensors. No delay boxes or other driver aided electronics. The application or use of any device, mechanical or electronic, that permit the driver to ascertain the position of their vehicle in relation to the starting line is prohibited.
• Progressive Nitrous controller system permitted
NHRA Rulebook:
: Delay boxes/Devices 8.2 under prohibited
: 8.7 switches
: 9.1 computer
Engine/Transmission:
• Trans Shield meeting SFI Spec. 4.1 mandatory in all cars running quicker than 10.99 or 135 mph
• Oil retention device (Diaper) recommended for all cars running 9.99 & quicker
• OEM or aftermarket transmissions with a maximum of 5 forward speeds permitted, including “clutchless” models. Any gear change must occur from direct action by the driver. Pneumatic, Electric, Hydraulic shifters prohibited. Clutch release devices prohibited. Trans brakes and 2-steps allowed.
• Jacket/Pants/Gloves/Neck Collar mandatory in all cars running 9.99 and quicker or 135 mph and quicker
• NOS permitted as well as other power adders
• No dragsters
