Supercharged Completely Polished Aluminum 540 Hemi Engine
MikeC55
Post by MikeC55 »
This 540 Aluminum Hemi engine is built for pro street or the racer who wants the horsepower and durability of a race engine and the drivability of a street engine. This Hemi is a fully water-jacketed motor with a hydraulic roller streetable cam shaft, the compression ratio is setup for pumped gas and comes with dual 850 Demon blower carbs. Makes 850 Horse at 6400 RPM's on pumped gas.
This Aluminum Hemi is a completely polished version, for Show car, Hot Rod, Muscle car, Boat, Truck or Tractor.
Hemi has all-new Components including:
Keith Black Street Polished Aluminum Hemi Block w/ steel sleeves and cross bolted mains (4.500" bore), Mopar Polished Aluminum Hemi Cylinder Heads, Mopar Polished Aluminum Valve Covers, Crankshaft forged 4340 Nitrided Stroker (4.250" stroke), 4340 H-Beam Connecting Rods, Manley Intake stainless steel 2.25" Valves, Manley Exhaust stainless steel 1.94" Valves, Crane Hydraulic Roller Camshaft, Crane Valve Springs Double Springs with Dampers, Crane Chrome-Moly Performance Spring Retainers & Hardened Keepers, Crane Hydraulic Roller Lifters, Crane Push Rods, JE Pistons Lightweight forged 7.75:1 Compression Ratio (4.500" bore), Intake & Exhaust Rockers Roller Tip, Keith Black Gear Drive Assembly & Polished Aluminum Front Timing Cover, Moroso 8 quart Aluminum Oil Pan , Keith Black Polished Billet Aluminum External High Volume and Pressure Oil Pump, MSD Electronic Billet Distributer, The Blower Shop Polished 8-71 Supercharger & Drive Components, Polished Aluminum Scoop with Air Cleaners
Additional Components:
1/2" head studs, 9/16" main studs, 1/2" side bolts on main, Heavy-duty performance engine bearings, SFI approved racing vibration dampener, Precision balanced engine assembly, Performance gaskets, Set up for external oil filter, 1" diameter oil pump feed line, Moly performance rings, Billet aluminum rocker stands, Hardened performance rocker shafts
Price: $32,500.00
EMAIL: mikec55@rocketmail.com
CALL: 509-467-7584
Last bumped by MikeC55 on Sat Nov 02, 2013 5:19 pm.
